Hi All,
I have a laptop and bought a new 60GB SSD as a boot drive replacement for my 500GB SATA, I then wanted to use the 500GB in a USB 2.0 caddy, for data storage.
I've installed windows 8.1 onto the SSD and it works fine, I then plug in the caddy SATA and it says, format the drive!
Used both power cables, so presume not a power issue. (Works with one anyway)
If I swap the drives back, (500GB in the laptop), it boots fine and I can see the SSD in the caddy fine as well.
Tried the SATA Caddy in another PC, same problem
Laptop has a BIOS, not UEFI, both are standard MBR partitions.
Any ideas?
Thanks
Any ideas?
Thanks
