Hi all.
I am unable to run my USB composite device with any stability. The device is a USB to PS/2-splitter (se photo). My OS is Windows 10 Pro 64-bit.
The device was intended to connect my PS/2 trackball and PS/2 keyboard to my desktop computer. When I have plugged in the USB composite device with trackball and keyboard connected to it, everything will run fine for maybe 10 minutes, maybe half an hour, some times even more, and then a message will pop up saying: "The last USB device you connected to this computer malfunctioned, and Windows doesn't recognize it." The message is signed Windows Explorer. On the Events-tab under Properties for USB composite device in the Device Manager, it says "Device USB\VID_046D&PID_C52B\5&f6a6a5f&0&9 was not migrated due to partial or ambiguous match." By the way, Device Manager shows two instances of the USB composite device. I don't know if that is normal.
The driver that installs when I plug the device in is an old Windows one: Version 10.0.17134.1 from 21 June 2006. I have already tried – to the best of my ability – to uninstall USB entries in Device Manager, and rebooted to have them reinstall.
In short: The device works just fine, until it is "thrown off" and I am told it malfunctioned.
Hope you can help.
