USB Disconnect Issue - Tried multiple fixes with no results
anarkeygodslam
69
System specs at the end, pieces are in order of age (newest to oldest, majority being around 2 1/2 years old)
The issue: About 2 weeks ago, my keyboard/headset/mouse all disconnected, each item either flickering or just shutting off. I tried to isolate each item, to no avail. I then went in and made sure BIOS and all drivers were updated, nothing. Next step was the normal search on the internet, and each one was either Windows 7 update (did not work), shutting off USB Selective Suspend (did not work), and turning off USB 3.0 (still nothing).
At first, when the USB peripherals would go awry, I lost control of the PC and had to unfortunately do a reset. I found out the second time that I could swap the USB cables to other ports, and regain control, albeit sporadically. I also found that I could plug into the blue (3.0) slots, and they would work (I am not 100% sure how the ports work, if I am still able to get usability from slots I previously turned off in BIOS). Precursors to the incidents now happen with either the mouse or keyboard alone disconnecting and reconnecting after a few seconds. Once this happens a couple times, all ports go out until I swap.
I appreciate any and all help in this situation, and if necessary I am willing to share any stats, images or unmentioned specs to help resolve my issue. Thanks!
Windows 7 SP1 (64bit)
MSI GTX 780Ti GAMING G-SYNC Support GeForce GTX 780 Ti 3GB GDDR5 PCI Express 3.0 Video Card
MAIN OS SSD: Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
SECOND SSD FOR GAMING/PROGRAMS: SAMSUNG 840 Pro Series MZ-7PD256BW 2.5" 256GB SATA III MLC Internal Solid State Drive (SSD)
XFX ProSeries P1-1250-BEFX 1250W ATX12V V2.2 & ESP12V V2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Full Modular Active PFC Power Supply
Logitech G35 USB Connector Circumaural Surround Sound Headset
RAZER DeathStalker USB Gaming Keyboard
Intel Core i7-3820 Sandy Bridge-E Quad-Core 3.6GHz (3.8GHz Turbo Boost) LGA 2011 130W BX80619i73820 Desktop Processor
ASUS Sabertooth X79 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
G.SKILL Sniper Gaming Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory Model F3
MX518 Optical Mouse
