USB flash drive not showing up in BIOS
Spartan191
50
Hey guys,
I'm making the move up to Windows 8.1 from Windows 7 but here's my problem. I have everything ready to go for installation but my problem is when I start up and go into BIOS to select my flash drive as the bootable device, it says it's disabled. How would I go about enabling it?
EDIT: My motherboard is an ASUS Crosshair V Formula Z.
In BIOS:
Under Advanced tab:
Legacy USB support - Enabled
USB ports - Enabled
Under Boot tab:
USB support - FULL Initialization (the other settings wont detect ALL your USB-devices)
Also check the "OS Type". It has 2 options, Win UEFI and Other OS. Try switching that too if the above didn't work.
Ugh, went through hell today. Last night I got it to boot up and was ready to install. The installer prompted me to format my hard drive so I did, then it told me it could not install. My backup was basically erased with my Windows 7 OS, and I didn't have a recovery disc (that I could find, at one point I did.) So I got W7 and then it told me my HDD was gpt partioned. Given up all hope, then I threw in an old hdd from a computer I haven't popped open in 2 years. Worked like a charm, first thing I did was fix my 1TB I would've preferred to have it on. Not going through that again, I'll wait until windows 9 arrives thank you very much.
Yeah, I tried every setting imaginable.
In BIOS:
Under Advanced tab:
USB ports - Enabled
Under Boot tab:
Thank you!!! solved my problem
I just wanted to comment that I had a similar problem for the last few days and here is what I had to do to solve it:
1. I own a DVD copy of Windows 7 Ultimate - create an ISO of the DVD
2. Use microsofts USB utility to create the USB installer
3. Use INTELs utility to load the USB 3.0 drivers into the images on the USB installer
https://downloadcenter.intel.com/download/25476/Windows-7-USB-3-0-Creator-Utility
Note: this took a while, probably at least 20+ minutes to complete, but it did work.
4. on the target PC connect the USB installer to any USB 3.0 port and install.
The problem that I was having was my new MoBo had only 2 legacy USB 2.0 ports, but I had my USB keyboard and mouse connected to USB 3.0 ports. Windows was having trouble detecting them because it could tell they were on ports it didn't have drivers for. I realised this because during the "failing" installs (which we failing with the "driver required" messages) my mouse was moving very lethargically "generically" you might say. However, after installing the USB 3.0 drivers, and user the "fixed" USB installer my mouse was responding rapidly as I would have expected.
I believe that as a workaround users should TRY and unplug everything from any USB port except a legacy USB 2.0 port. In my case I would have had to remove my keyboard while insalling windows and just use the mouse, and hopefully hot-swap them back and forth. I am not even sure that would work, so good luck if you try that. Otherwise, I suggest you use the linked intel utility to load the USB 3.0 drivers onto you existing Windows 7 USB Installer.
Hardware:
Gigabyte GA-Z170X-Gaming 3 ATX LGA1151 Motherboard
USB Keyboard
USB Mouse
USB Thumbdrive loaded with Microsoft Windows 7 Ultimate 64bit
I tried all of that, but the USB still doesn't appear in my BIOS. I have used software to verify that it is bootable. Help?
In Bios, go to hard disk and select the 1st hard disk as your USB drive and second hard disk as your computers hard disk. Then go to boot device priority and the USB option will be visible; you may set as the 1st boot device.
It is an old question and I meet it today. I comment that the problem emerges on my pc when I insert usb in the front of it but solves itself when I insert at the back.
