It depends how far you need to go. To actually convert a USB drive to run over network you need a device that makes it look like a NAS. Many routers have that function but they also make small nas devices that with just a USB port and ethernet port. It seems the most popular way is to use a raspberry pi to do this but I am unsure how well it really works.
The limits on usb cable is about 15ft even less if you are using usb3. There are a number of solution that try to use physical ethernet cable to extend the distance but they are more designed for things that need low transfer rates like a printer. They also have trouble providing power. There are a number of USB hub type of devices that try to extend but in your case it...
The limits on usb cable is about 15ft even less if you are using usb3. There are a number of solution that try to use physical ethernet cable to extend the distance but they are more designed for things that need low transfer rates like a printer. They also have trouble providing power. There are a number of USB hub type of devices that try to extend but in your case it will be cheaper to buy a small NAS.
