USB headers on motherboard
Swaggernaut
21
the motherboard i want which is a ASUS Crosshair V Formula 990FX only has 4 pin fan controlers but i have fans that are 3 pin fans. can i plug them in there, if not what do i plug them into
Yes You can !
look you old 3 pin mobo conector and keep the lead pin on the 4 pin conector
In most of the motherboard the black pin is 1 pin
Yes You can !
