P penguin233527 Commendable Oct 11, 2016 2 0 1,510 Oct 11, 2016 #1 I have headphones. They have light with usb, mic jack and a headphone jack. When i plug in usb for lights there is some noise. how do i fix it?
ssddx Titan May 27, 2009 17,050 5 74,965 Oct 11, 2016 #2 you could try using a powered usb hub. having the ground plug generally reduces noise from usb. it sounds like your system is getting a high amount of interference on usb so i'd try that first. Upvote 0 Downvote
P penguin233527 Commendable Oct 11, 2016 2 0 1,510 Oct 11, 2016 #3 i did nothing helps Upvote 0 Downvote
ssddx Titan May 27, 2009 17,050 5 74,965 Oct 11, 2016 #4 same issue on another pc? same issue both front and back ports? Upvote 0 Downvote
