Hi friends!
How’s everything? I hope you are all well...
Pls, I have a computer with two 3.0 cables (3 m. long) and a "USB 3.0 Hub" powered by 5V (volts) and 3A (amps). The problem is that when I plug in the HUB and connect a USB hard drive to it, it starts to connect and disconnect continuously. A headache. I tried connecting a simple pendrive and it works fine, but of course, a pendrive uses a very small amount of power.
Could the cable be a problem? Any idea?
I would appreciate any help.
THANKS IN ADVANCE.
THANKS IN ADVANCE.
