Hi!
I got an USB HUB yesterday in order to connect to my extension USB cable that is connected to my motherboard. I know this is confusing, but I put my case above my monitor and I usually play my games using my TV and laying on my couch. To use my headset, I had to buy this Extension USB cable (3m long) so I could use it on the couch. Today, I bought this micro USB cable (3m long) to connect my Xbox controller to the USB Hub. BUT, the controller only works if the HUB is connected to the motherboard directly! Also, If I plug the controller to the extension USB cable, doesn't work either. What am I doing wrong here? My plan was to connect both my Headset + Controller to the HUB and use my Extension USB to connect the HUB instead of using my motherboard. Both my HUB and the other cable is 2.0
