[SOLVED] USB issue
For some reason if I plug a USB device in while my computer is on it isnt detected. At first I thought it was just my USB external drive, but then my webcam wouldn't work (they are on a switched usb hub) so I confirmed this by unplugging my mouse and plugging it back in on the motherboard usb , nothing. RGB didnt light up and it was not recognized.
I tried to disable USB selective suspend to see if that would change it and nothing. This is a brand new issue, literally had no problem two days ago and now I do. I havent changed or added anything . Any idea?
W
Update your post to include full system hardware specs and OS information.
In Task Manager > View tab is "Show hidden devices" selected?
You mentioned "switched USB hub": make, model, number of ports? Independently powered?
Windows 11 and my hardware is in the signature. The switched hub isnt the issue but its a Sabrent 4 port hub with individual power switches.
As I said I confirmed the issue by using the ports on the back of the motherboard. Weirdly the issue seemed to resolve itself. I have absolutely no clue what was going on with it
