USB Monitor won't work
btr999
118
Hi,
I have a gtx1080, running windows 10 with a 27 inch monitor. I just got a AOC E1659FWU usb monitor and I tried to set it as my secondary monitor.
When I boot into windows, both monitors show desktop for a few seconds and the usb monitor will go black screen. The main monitor (27" connected to gpu) will keep going on and off and the pc is not responsive until the usb monitor is completely undetectable from my display setting. After that, the main monitor works fine but the usb monitor just won't show anything even reconnecting usb.
I have installed displaylink driver and aoc monitor driver to latest version. Nothing works.
When the usb monitor stopped working, in Device manager, it shows
"Windows has stopped this device because it has reported problems. (Code 43)"
Any idea how to fix this?
Update - apparently it was Nvidia Share that prevented the usb monitor to connect properly. I turned it off and worked like a charm. But now i need to figure out how to enable Nvidia Share and at the same time have usb monitor connected.
Thanks for your help
