USB mouse connecting and disconnecting frequently
Yamdox
9
Hi guys, as stated in the title I have this problem that I found has something to do with USB ports and drivers.
The USB mouse keeps connecting and disconnecting frequently and sometimes disconnects totally, even if I plug it in again.
I found that in the "Device Management" window, under "USB Controllers" there's a "Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26" which driver, if deactivated and reactivated, makes the mouse working again.
I read in some threads that it could be a lack of power but I didn't add anything new to the computer recently and everything was working fine before.
Hope you can help.
I don't think it will get away on its own since the problem has been there for more than 2 weeks and even got worse in the last 3 days. The mouse now stops working after like 0.5-1 hour.
It's getting hard to do anything without having to restart the computer or restart the driver and I noticed that the latter doesn't even work always.
It's a power setting issue:
You can go through the list and use the settings that best suit your system.
A. When these power saver features are enabled, it causes a bunch of problems.
B. Windows shuts down your system to sleep, hibernate, standby, etc..etc...
C. After shutting down system to "save power" the system malfunctions when you try to wake it up again...and locks up, freezes, etc...
It locks the mouse, it locks the keyboard, it shuts off the display, and locks out the hard drive, it shuts off USB devices, etc...etc...
D. This will cause you to pull your hair out, and go to the funny farm...(those nice young men in their pretty white coats)
E. Make it stop, please make it stop.
F. Shut off all these "features" and USE your computer for a change):
Click Start, Click Control Panel,
Look at the top of the window, in the path bar you see “control panel >”
Click on “>” (in the path bar) now click on “all control panel options.”
(This will open up all the hidden controls available)
Click Power Options
click on the arrow to “show other plans”
Check the Box that says "high performance"
Click (in high performance) "change plan settings"
Turn off display: set to NEVER
Put the computer to sleep: set to NEVER
Click: Change advanced plan settings
Scroll down the list: Click on the + signs to expand the choices for each item on the list.
Require a password on wake up: set to NO
Hard disk: turn off the hard disk: set to NEVER
Wireless adapter settings:
Sleep: set to NEVER
Allow Hybrid sleep: set to NEVER
Hibernate after: set to NEVER
Allow wake timers: set to disable
USB settings:
USB selective suspend setting: set to NEVER
Power Buttons and lid:
Power button action: Setting: set to shut down
Sleep Button Action: set to: do nothing
PCI Express:
Link State Power Management, Setting: OFF
Processor Power Management: Minimum state (set to) 7%
System Cooling Policy: setting: Active
Maximum State (set to) 100%
Display
Turn off display after: setting: NEVER (turning off display automatically can cause freezing also)
Turn off the monitor power manually, when you want it off. Don’t use the auto monitor turn off.
Multimedia Settings:
When Sharing Media: Setting: Prevent idling to sleep
When Playing Video: Setting: Optimize Video
Click APPLY
Click OK
Open the bios set up and make sure "cool and quiet" is OFF. (AMD)
If there is a power saver or a "quiet mode" in the bios, shut it off...
There may be a performance setting in the bios setup you have...make sure it's cranked up to max.
in the bios, see that the allocation for video, if available, is maxed.
Now open the hardware manager profiles...
click start
click computer
click system properties
click device manager
double click on mice and other pointing devices
right click on HID compliant mouse
left click on properties
click on the power management tab
UN-check the box that says: "allow the computer to turn off this device to save power." (there is now NO check mark in this box)
click OK
Now repeat this procedure for all mice, monitors, keyboards, and ALL USB ports on the device manager list.
You must open ALL the devices one at a time, as above, and turn off the power saver, for each device.
NOW turn all the security back ON. NOW open your security antivirus. Make sure the antivirus is set to "gaming mode." Or "multimedia mode."
This prevents the security updating from interrupting your game / multimedia priority.
IF the security does not have "gaming mode" or "multimedia mode" get different security.
IF you are using "free" security downloaded from the internet, get rid of it NOW.
Use ONLY professional all in one security. DO NOT load multiple mismatched security programs, which conflict with each other.
DO NOT load free tools into your system such as: "driver sweeper" or any of that "free" goofy stuff.
