Question USB port connection of ADATA HD710 PRO 2TB
Jan 26, 2023
4
Hi,
The USB socket of my external hard drive, ADATA HD710 PRO 2TB, to which its cable is connected, has been removed from the board, and I want to connect it to the board again, but I do not have a picture. to show the physical and circuit connection of it. Please help me because I have stored a lot of information in it.
Thanks,
Hi,
Thanks,
So what is your issue?
According to the video, there is a regular SATA HDD inside. Remove the drive and connect it to a SATA port inside your computer. Hopefully there will be no encryption or sector translation.
https://www.youtube.com/watch?v=2KXguipHK74
Thanks. Which converter cable should I buy for that; SATA to USB/HDMI converter cable? Is it a simple SATA to USB/HDMI converter cable or should buy the electronic bread board 2 on the
attached screen shot at the following?
And how to connect connector 1 to bread board 2 as the attached screen shot at the following?
The screen shot;
https://www.mediafire.com/file/xhkkl7cf4ibb2m5/ADATAHD710PROparts.jpg/file
Thanks,
