USB Ports not working/ qcode 00/ fail post test
Jonny Hue
104
I've updated bios , checked all my plugs/ no beeps and my screen isnt showing anything..
also my usb ports work for 1-2 seconds and stops
can anyone text message me and help me fix it? I'll send you a few bucks on paypal..
I'm not able to post pictures on here since it takes forever
its going to be hd audio--unless you put hd audio in the usb 2.0 port
wait yea i plugged in pci-e cables but i dont have anymore of those 8 pin connectors only three x4 onnes
they are seperate each one has 4 connectors on it. i cant find the 8pin lol
ohmy i think im holding the 8-pin in tiny lets on the wire it says CPU 300w etc
that sounds possible--it wont fit in if its the wrong cable and the only other 8 pin should have pci-e written on it
its so short its so hard to plug in
OMFG IT WORKS NOOWOWOWOWOWOWOW
at first the pc switched on and off twice and i got sad and now im in bio screen!
OMG THANK YOU SO MUCH
there we go--dont worry if it does the on off on thing its common on asus boards
first thing in bios check cpu temperature before doing anything else
what should the cpu temp be
