G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
I have installed win xp pro on a new computer and all seems fine.
I have tried to add an Epson C44 usb printer but it will not work. The
drivers are loaded and the computer has the information in printers that a
C44 is the default printer. However the PC will not 'see' the printer,
during setup the computer should search for the printer but it did not find
it, I was able to load the drivers anyway.
I think it is the USB port that is at fault as I have tried the cable and
printer on another computer and they work. I have tried the printer in each
of the 4 usb ports and nothing.
When the printer is turned on it makes that sound you get when a usb device
is plugged in but it does not show on the taskbar.
I have uninstalled and reinstalled the drivers without luck.
In device manager the usb controller is shown.
Hope the above makes sense.
Does anyone know what I need to do to get the printer talking with the
computer.
Many thanks in advance.
computer.
