I recently built a new system with Gigabyte GA-AB350M-DS3H and a Tecware Quad Case with One USB 3.1 Gen 1 and Two USB 2.0 Front Panel USB Headers.
My problem is that every time I use these front panel USB headers, the safety remove device icon does not show on the taskbar unlike when flash drives are connected at the back panel I/Os. The flash drives connected to the front panel USB headers can be used and manually ejected on explorer though.
I'm using Windows 10 1803 with all drivers installed.
Thanks in advance for replies!
EDIT: Ultrafast boot is enabled. I think this might be the culprit since it might? not initialize all USB ports. Not sure.
