One minute test with the driver uninstalled:
CONCLUSION
_________________________________________________________________________________________________________
Your system appears to be suitable for handling real-time audio and other tasks without dropouts.
LatencyMon has been analyzing your system for 0:01:00 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-6P2SC6D
OS version: Windows 8 , 6.2, build: 9200 (x64)
Hardware: Alienware 17 R4, Alienware
CPU: GenuineIntel Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
Logical processors: 8
Processor groups: 1
RAM: 16253 MB total
CPU SPEED
Reported CPU speed: 2808.0 MHz
Measured CPU speed: 3577.0 MHz (approx.)
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 210.415916
Average measured interrupt to process latency (µs): 4.374242
Highest measured interrupt to DPC latency (µs): 182.700821
Average measured interrupt to DPC latency (µs): 1.212165
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 42.071225
Driver with highest ISR routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total ISR routine time (%): 0.001877
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0.001877
ISR count (execution time <250 µs): 7174
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 393.262108
Driver with highest DPC routine execution time: ntoskrnl.exe - NT Kernel & System, Microsoft Corporation
Highest reported total DPC routine time (%): 0.039399
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 391.01 , NVIDIA Corporation
Total time spent in DPCs (%) 0.136067
DPC count (execution time <250 µs): 198460
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 1
DPC count (execution time 1000-1999 µs): 0
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
Process with highest pagefault count: none
Total number of hard pagefaults 0
Hard pagefault count of hardest hit process: 0
Highest hard pagefault resolution time (µs): 0.0
Total time spent in hard pagefaults (%): 0.0
Number of processes hit: 0
PER CPU DATA
CPU 0 Interrupt cycle time (s): 3.003323
CPU 0 ISR highest execution time (µs): 42.071225
CPU 0 ISR total execution time (s): 0.009012
CPU 0 ISR count: 7174
CPU 0 DPC highest execution time (µs): 164.388889
CPU 0 DPC total execution time (s): 0.554965
CPU 0 DPC count: 177841
CPU 1 Interrupt cycle time (s): 2.981738
CPU 1 ISR highest execution time (µs): 0.0
CPU 1 ISR total execution time (s): 0.0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 121.833333
CPU 1 DPC total execution time (s): 0.018076
CPU 1 DPC count: 3703
CPU 2 Interrupt cycle time (s): 2.553088
CPU 2 ISR highest execution time (µs): 0.0
CPU 2 ISR total execution time (s): 0.0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 141.815883
CPU 2 DPC total execution time (s): 0.022824
CPU 2 DPC count: 4593
CPU 3 Interrupt cycle time (s): 3.630472
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 67.673789
CPU 3 DPC total execution time (s): 0.003372
CPU 3 DPC count: 737
CPU 4 Interrupt cycle time (s): 3.016603
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 393.262108
CPU 4 DPC total execution time (s): 0.018445
CPU 4 DPC count: 3749
CPU 5 Interrupt cycle time (s): 2.798776
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 124.254986
CPU 5 DPC total execution time (s): 0.010855
CPU 5 DPC count: 2442
CPU 6 Interrupt cycle time (s): 2.445775
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 118.295940
CPU 6 DPC total execution time (s): 0.017475
CPU 6 DPC count: 3812
CPU 7 Interrupt cycle time (s): 3.589673
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 62.180199
CPU 7 DPC total execution time (s): 0.007274
CPU 7 DPC count: 1584
