USB sound adapter malfunction!
Marinik
My USB sound adapter (3D sound) malfunctioned, i now only hear one chanel (mono sound), my headphones work fine on other devices. Please help me, can this be fixed??
inspect the inside of the usb connector of sound adapter
try to make sure no pins are bent
also go to device manager (right click my computer>manage>device manager)
select the device from the list and uninstall driver
unplug usb audio
then restart computer and then plug in the sound adapter
and let windows reinstall driver or you might need to use the driver disk that came with it
also go into the start menu>control panel>hardware and sound>check settings for audio device in the properties menu
try this and report back
There is no model number writen, it's just like the one in the picture on the link you sent me. I tried instaling both versions from the link... neither worked
