[SOLVED] USB unplug and plug sound appears constantly
itamar6531
9
Hi!
I have a big problem with my pc, whenever I use my pc the USB unplug and plug sound appears constantly, (with this I mean the sound the pc makes when you plug and unplug something haha) and I thought it was some kind of damaged device, but I've disconnected almost every usb cable I have on my pc and the problem doesn't seem to be fixed. It's kind of annoying because the sound just appears almost all of the time. I've looked up in device manager and windows says it's an unknown device that's causing this, and this makes it even more difficult to solve because I don't know which one it is. I've tried uninstalling the device driver, unplugging almost all of my usb ports and using troubleshooter to fix this, but it just doesn't work. I'll write down the device properties if this helps, the text is in spanish, but I'll use google translate.
By the way, any help would be really appreciated!
The USB device \ VID_0000 & PID_0002 \ 6 & 3af0f9ce & 0 & 6 was configured.
Driver Name: usb.inf
Class GUID: {36fc9e60-c465-11cf-8056-444553540000}
Controller Date: 06/21/2006
Driver Version: 10.0.18362.1
Driver Provider: Microsoft
Driver section: BADDEVICE.Dev.NT
Controller Rating: 0xFF0000
Corresponding device ID: USB \ DEVICE_DESCRIPTOR_FAILURE
Top drivers: usb.inf: USB \ DEVICE_DESCRIPTOR_FAILURE: 00FF2000
Updated device: false
Main device: USB \ ROOT_HUB30 \ 5 & 4087d53 & 0 & 0
First i would try updating the driver.
Go to the motherboard makers download page for it.
Second possible cause would be bad caps on the motherboard that control USB 5v voltage.
I have had both happen.
