USB virtual printer port not available for HP 6540
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Trying to connect HP Deskjet 6540 to a vanilla Dell USB port. Expecting the
"New Hardware found" dialog but there is no reaction. Trying to add the port
type myself doesn't work - even though HP provides a driver. Device Mgr
shows all the USB ports and controllers no problem, and there is a USB mouse
on the PC so I believe the BIOS is okay.
All suggestions welcome!
Did you install the software before you connected the device?
Cari (MS-MVP)
Printing & Imaging
"John F" <john@taminc[nospam].com> wrote in message
news😀4F9812B-6858-4B02-89CD-3C9A8DB9F7FF@microsoft.com...
> the
> port
> mouse
Isn't that one of the printers that you need to run the complete
software install before you attach the printer? Double-check the
installation instructions.
It says to insert the CD once the "New Hardware Found" message comes up and
you choose "Have Disk".
However, as you suggested, I just tried installing the software first and
still can't locate or create a USB virtual printer port.
I have verified that the printer and USB cable are both good by connecting
to my laptop - the NHF message came right up, even with Symantec AV enabled.
You may need to temporarily disable A-V. I occasionally have had
non-discovery of "new" USB devices with A-V enabled and as soon as I
unloaded A-V, it worked as expected, re-enabling afterward to resume
protecting the system.
