I am wondering is it feasible to use both the built in Intel UHD Graphics 770 GPU in the i7-13700 CPU and the dedicated AMD RX 7800 XT graphics card at the same time to output display on multiple monitors?
I read there is some BIOS settings if the motherboard support it. So I plan to get the Asus ProArt Z790 to take advantages of the 3 onboard HDMI and display ports, I assume that means I can connect up to 3 monitors to the motherboard using the 770GPU, correct? Plus 4 HDMI/display port on the RX 7800 XT graphics card, if I am on the right track.
Does that mean I can connect up to 7 monitors using the integrated GPU and dedicated graphics card? Cause if yes, that would save me some space and PSU quota for 2nd dedicated graphics card.
Thank you.
Thank you.
