Question Use Epos sennheiser gsx 1000 with wireless Head set
Jul 3, 2023
I have Epos sennheiser gsx 1000, and would like to get epos audio h3pro hybrid wireless head set, The head set has a usb dongle and i was wondering if there is an adapter (usb to 3.5) that i can use to plug into the gsx 1000. I like to switch from headset to speakers and the gsx 1000 is great but i hate wired headsets.
IMHO, you might want to forgo the idea about using that amp with that headset. The headset should be plenty without the need for an amp and would also cut your expenses down as well.
Your headset is also analog driven, you could look into plugging that to the amp if you're absolutely invested in the idea of that headset/amp pairing.
