Question Used prebuilt no signal on any port or monitor. Red then yellow Lights on motherboard, Asus B550-F, Ryzen 7 3800x, RX 5700XT, 16gb DDR4 Vengeance Ram.
Sep 13, 2022
8
Bought a used pc specialist pc from eBay, worst case scenario I get my money back. Current issues: Powers on, lights up, GPU fans don't spin but there's 2 solid blue lights. 1 long beep, 2 short beeps then stops. Motherboard has red then yellow lights on 2 sticks of ram.
With 1 ram stick there are no beeps and no yellow light, but still no signal. (Might be defective ram stick or slot, only does it with the 2nd ram stick?) DP is plugged into the GPU, GPU is plugged in properly, CPU has been reseated still no dice. CMOS has been replaced and reset. Tried 3 different power cables, 2 different displayport cables, a different monitor etc.
I've tried literally everything short of taking out everything and re plugging back in, flashing the bios, and resetting the CMOS battery with a screwdriver (I used a new battery instead). Apparently it was "working before delivery", but since arrival it's been a dead end. Just no signal/picture, even on my brother's monitor. I'll be honest with y'all, it's doing my head in. Please help.
This one is asus beep codes:
https://www.asus.com/support/FAQ/1029959/
One long beep 2 short
3. "One long and two short beeps" from speaker
An anomaly is detected in memory. Please confirm that the memory is correctly installed.
Please refer to the Motherboard manual for related instructions about memory.
q led codes - doesn't tell you the color
a cpu
b dram
c vga
d boot
The beep code is memory. What's the part number of the dimms? To check the qvl for compatibility. Might be either faulty or incompatible memory.
Some might say if they had a spare dimm, try that instead. Others might think bleh troublshooting doas and send some back.
Tried spare ram, still had issues.
"working before delivery" are just words on a screen.
It is a used system, that apparently does not work after delivery.
Either one or more components are loose, or one or more components are faulty.
or both.
What are the full specs of this unknown system, what 'prebuilt' company, and how much did you pay for it?
or both.
Hi there mate, paid about £510, and the company who built it is pc specialist, the fnatic gaming pc. Specs: Asus B550-F, Ryzen 7 3800x, RX 5700XT, 16gb DDR4 Vengeance Ram.
Specs generally include
The exact Memory Part No. Psu Make and Model. Drives, Fans etc.
The situation you are in is basically trying to refurb a used PC, with apparently little interest in the tech specs
eg. List
Cpu:
Cooler:
Mobo:
Memory: Model Make and exact Part Number.
Drives: HDD, SSD, NVME quantity of each, make and model of each
PSU: Make and Model
Case/Chassis:
Optional Fans:
Operating System:
Optional Extras:
Like so.
However if you are sending it back there's no need to bother with all those finiky details and perhaps you'd be better of buying a pc off the shelf from the high street instead.
Hmm, I'd have to get back to you for the specs, they couldn't even tell me themselves. Liquid cooled CPU, no PSU (some other method) , 2tb HDD, 512gb ssd, I'll need to get back to you with exact names and stuff. Panning to (hopefully) not cheap out this time. Praise the lord for Money back guarantee.
Simple you bought a PC and it's not working, return it for a refund or another PC.
Generally you can read the labels on the devices. You appear to have a peculiar blend of hardware. A modern system would not contain a hdd and well I simply cannot imagine how you even switched on the computer with no psu (power supply unit) installed.
The memory needs to be matched to the motherboard if you custom build a machine. Then you will have to search for a vendor in your locale and determine if they have the parts you want. First you need to know what you want.
You won't have to figure out the memory compatibility if you simply buy a pre built from the high street. it will already have matched memory in it.
However if you buy from the high street you might miss a few extras if you're savvy enough to build it. If you simply do not understand the specifications of a PC you will have some problems if you try to buy one and you learn it doesn't do what you wanted later.
Tx650 psu mate. Corsair vengeance RGB pro 3200mhz.
