I don't trust tech-tubers of any kind, because a lot of them have relationships with NVidia that could be tarnished if they came out with some damning evidence against them. Im betting (though I could be wrong) that a techtuber would no longer recieve "free cards for testing" if they said something NVidia didnt want them to say. Those contracts and NDAs are very strict. I wouldn't doubt it if NVidia discovered the problem first, told the techtubers to make videos that they wanted viewers to see, then came out and said "Oh ya, the tech tubers were right. Its user error. Even if this is not the case, even if the tech-tubers did a 100% neutral unbiased objective test, those were short lived. Running on full load for 15 minutes, and then saying "Ya, no melt here. User error" doesn't count. Did any of those tech tubers do a build inside the case, plug it the GPU in once, leave the cable alone and not touch it again like most normal builders do, then run a 2 day full load test? That's what I would like to see. Testing in a controlled environment doesn't really help much. I want to see it done in a real-world typical situation, from the perspective of someone who just bought a 4090 and doesn't know about the melting problem. Let's see how the test goes.
Definitely don't trust random sources, but do remember that goes both ways. Just because a source is suddenly anti-big company, doesn't make it trust worthy.
While there are some cases your fears are quite founded, Nvidia has traditionally not been one of them. ( BTW sites like tom'sHardware here are just as subject to the same things as any tech-tuber, and again for any magazines, blogs, etc. )
However, a number of companies have been quite negative of Nvidia at various times, but still receive review samples, etc. I'm sure there are various restrictions, and things to sign ( and breaking NDA is a good way to actually make it onto a ban list ), but they haven't seemed to retaliate much for simple negative press.
For example, early on in this cable mess, those same tech-tubers hammered the disaster of melting cables.
It's definitely something to watch out for though, and I'm sure a constant headache for tech review companies.
As for the long duration real world testing, some of the tech-tubers did try that to an extent, but that's rather moot. There have been literal millions of RTX 4090s sold and without issue.
As mentioned, I personally have had a 4090 pretty much since launch, and know multiple other people with 1, and there are many companies running them 24/7. The test has been done in the real world. I have never met a single person that has actually had a melted cable, either personal or business.
Exactly, because the problem here.... is that those tiny little pins on the new connector are not designed to safely and reliably output 450W long term without issues, That's why 4090's have this problem, not 4080s or less. This is a design flaw, not user error
Completely wrong: They are actually designed for significantly MORE than that.
As I said before, they are even capable of 1,000w.
I get that, but I would fully encourage someone like LTT or GN to fly down there and do an in person vett of this person and I bet they are telling the truth.
Yea, I was hoping to find some sort of vetting one way or another, but so far I haven't found anything. No other repair shops have come forward and said one or the other, no one has done a verification or debunking. All I have seen is 1 tech-tuber repair shop advertising his shop while making a pretty extraordinary claim. And extra-ordinary claims require extra-ordinary evidence.
....Or..... because of the design flaw, the cable slowly came out over time after the user had completed the builds. Remember, not all the melts happened 1 day after using the freshly built PC. Some of them happened after a year. So a user with 20 years experience, who doesn't know about the melting problem, does a build, plugs the cable in all the way, the same way he has for 20 years building PCs. Over the next 4 months, the cable slowly comes lose, as well, the gamer found a very demanding high-wattage pulling game that he's binge playing to level up fast, constant high load, boom, theres the melt.
The cable can only come out if it was not fully seated. It has a very firm and secure latching mechanism, as I can personally attest to. I suspect if I pulled the cable hard enough, the connector might pull from the PCB before the latch gives loose. ( Obviously, I'm not going to try that far. However, early on with the issue, I wanted to make sure my cable was plugged in, so I gave it a bit of a pull test and confirmed it was secure. )
False. It can be reproduced in many ways, such as what my 20 year-experienced builder did in the previous paragraph, and has happened to a great many builder as well, even ones who did research and knew about the melting problem before building
I'm not sure who you mean there, though I suspect it was the person that sued, as he made pretty much exactly that claim in the filings.
Except his own pictures clearly showed that the cable had not been properly seated.
I would also recommend caution with him. You might want to look him up more, but I don't want to get into a targeted statement on an individual, but want to stick to known general facts.
More generally, no, no one was able to reproduce the issue without having the cable partially unplugged. This included tech labs: Bends did nothing, overclocking did nothing, damaged cable did nothing, disconnecting 1 of the 4 cables did nothing, the different pins styles didn't matter. There was only ever the cable not fully plugged in that could get hot enough to melt the connector.
I didn't think I would hafta say it, because I thought it was quite obvious, but I guess not. So here goes: I was exaggerating.... just a tiny bit.... to make a point
Making a false exaggeration hurts an argument though, especially on the internet where you can't trust someone actually is using hyperbole or joking.
A partial fix has been implemented. I'm sure its helped a little bit.... but obviously not, because some cards are still melting
Yes, it has happened to other cards, but not nearly as much as the 4090, because as discussed at the start, power draw is a factor
I don't doubt that the connector can work, if set up a specific way. I'm sure there are plenty of 4090's that are doing just fine. They just haven't come loose yet. It also depends on the case, the form factor, the cable guage, that sort of stuff matters. Bottom line is, this shouldn't be happening at all, or at least it should be extremely rare
0.05% is pretty rare. Sure, it'd be nice if it wasn't a problem at all. Heck, that's why I have been following it so closely. I'm "an invested party". If there was a defect in the cable, I would want to know so I could return or replace mine.
But no real defect has been found. It's not as user-friendly as it could be, but there's an important distinction between the 2. 1 is saying it works as designed, the does not. The cable is the latter, it works as designed.
An example would be the body armor I had in the Army. It was a bit heavy, and when you sat down it could be uncomfortable. These were things that could be improved for a better user experience. But, it still could stop the bullets it was designed to stop, as long as it was wore properly. Now, some people might not have worn it properly because of the poorer user experience, but that was them making a major mistake over the top of the minor comfort issue. ( Insert Starship Troopers don't remove helmet. )
I didn't know these companies offered RMAs for cards that were broken due to user error. Maybe this is the admission of their error, and maybe all the RMA offers were why the class action lawsuit never happened
Well, naturally it started for much less "altruistic" reasons: Nvidia just wanted hands on as many as possible so they could investigate any/all possibilities. This even included them asking AIBs to send cards their way.
Once it was found to be user error though, it would have looked really bad to turn around and start rejecting RMAs they had been doing. Presumably, they then determined it was sufficiently rare that it was easier and cheaper to just continue with it as is. Cost of PR. If it had been a big issue, they would have either stopped manufacturing or done a recall, to prevent the costs of endless RMAs piling up.
I'll tell you myself: the very second i first laid eyes on that connector, BEFORE the 4090 melting problem first cropped up, I knew right away this was going to happen. I took one look at it right and away and I was like..... ya.... there's no way those tiny little pins are rated for 600W. This has to be some kind of joke. Bottom line is this, while the user does have steps they can take to mitigate the problem, they shouldn't have to do that. Plugging in a 4090 shouldn't be a specific, detailed intricate process. At the end of the day, all we are doing is plugging a plug into a socket, something we all have done a billion times. It shouldn't be this hard. You plug it in once, and forget about it until you need to unplug it again. This is how electrical plugs have worked since their invention. A person should be able to just plug in a 4090, make sure the connector piece reaches the end on the socket on the 4090, then not touch it again, run 450W around the clock, go on vacation for 2 weeks with peace of mind. That's how it should be. It isn't this way. It always has been for as long as electric sockets have existed..... right up until the 4090.
This entire problem, from top to bottom, through and through is 100% design flaw and 0.00% user error. It always has been, and it always will be, that's just the fact. The 16-pin connector should never have been created. It's a fire hazard. The 8-pins were a well matured standard and have worked for years. If it ain't broke, don't fix it
Completely disagree. As mentioned, your initial assumption is just wrong. And it shouldn't be surprising: This cable is way beefier than cables rated at significantly higher power levels.
I just plugged some worst case scenario numbers into a wire-gauge calculator. At double the power, 5% voltage drop, and maximum allowed temp of just 100 F, you get 20 AWG. The cable is 16AWG. ( At 16 AWG it is good for 13A per wire )
