Hello everyone, I’ve read similar threads but still find myself confused, so I hope someone can clarify this for me.
I’m building a new PC and planning to use a Sapphire Nitro+ Radeon RX 7900 XTX GPU with a be quiet! Pure Power 12M 850W PSU. However, I noticed that my PSU has only two PCIe 12-pin slots, each with cables that have two 6+2-pin connectors (daisy-chained). I will attach an image with the cable.
The GPU requires three PCIe power connections and the Sapphire Nitro+ model is known to have the capacity to draw more power than other models (+450W).
I read a lot of takes about using daisy chained cables or not, but I still don't understand exactly why because there are a lot of contrary opinions.
From what I understand:
- A single PCIe 8-pin connector supplies up to 150W to the GPU
- Some say that daisy-chained cables from high-quality PSUs can safely handle more power (I read mostly about 288/300W), depending on the cable gauge and PSU design
The only specification I found about my PCIe cables is that they are 16-18 AWG, but I’m unsure how to calculate their maximum power handling capacity.
But if let's say we assume that each cable can handle 300W, does that mean my GPU would get:
- 300W (150W x 2 from the daisy-chained cable),
- 150W (from a single connector on the second cable), and
- 75W (from the PCIe slot),
for a total of 525W?
Or I could only get 150W in total from the daisy chained cable regardless?
I’d really appreciate it if someone could explain to me how this works and if I could use my GPU to full potential with this PSU.
Thank you for your help!
