I've got a NH-D15 tower cooler attached to a i5 13600K. I'm only using the single fan because space in the case is a bit tight. It is physically possible to attach the second fan, but it's very tight.
So the optional fan is doing nothing atm. And that's ok, because it is optional anyway and the CPU doesn't need it.
I've got an unused fan slot on the top of the case (Fractal Design North). And i'm thinking of using the optional NF-A15 fan as a top mounted exhaust fan.
Is this a silly idea? Should i buy a 140mm case fan? Or just not bother? Temperatures are fine and there is no noise problem.
The only reason i'm thinking of doing this is because i've got a fan that's doing nothing. I can always attach it to the cooler later if it becomes neccessary.
Noctua's blurb says: "The NF-A15 is tailor-made for use on today's high-end CPU coolers: While its 150mm width matches blah, blah, blah, heatsinks, its 140mm height yadda, yadda, case compatibility. The NF-A15's standard 120mm mounting holes (105mm spacing) also make it an ideal performance upgrade for 120mm case or CPU fans."
So it should be fine to do this, but please check my head.
Additional question: Should i hook up all case fans to individual MoBo headers, or use a case hub? Would PWM be sillier if i used multiple headers? Or is the hub simply for controlling multiple fans using one curve/setting?
Thank you.
Case: Fractal Design North, with two 140mm front intake fans, and no exhaust fan (default North config). I will be adding a 120mm exhaust fan very soon, a Noctua NF-S12B Redux-1200 PWM. That is a slower fan, designed for case ventilation.
CPU: intel i5 13600K (not overclocked)
GPU: 4060, Gigabyte Eagle OC (not overstressed. not even stressed)
Motherboard: Gigabyte Z790 UD
Thank you.
