Introduction
I'm just posting this little note, in case it helps someone else. Maybe not trying to use this specific cooler on AM4 or AM5, but perhaps you've got some old Cooler Master model and are wondering if it can still be used.Background
Recently, I had a need to use an alternate cooler on an AM4 board/CPU. I won't go into the rationale, but another relevant fact is that I have a newer Cooler Master model I couldn't use on it, which included an AM4-compatible mounting option (the included hardware with my M4 supported only up to AM3, for AMD CPUs).The Geminii M4 is top-down cooler I bought for $35, back in 2012. It has 4 single-ended heat pipes, using "Direct Touch technology". I had recently used one of their direct-touch tower heatsinks, in another machine, and was pleased with how well it performed. So, I got the M4 for a machine where I deemed the "down-draft" style to be more appropriate. At the time, I hadn't seen many reviews of down-draft coolers. This style of cooler rarely performs on par with the towers, and therefore tends not to be covered as well by the tech press. After I had bought it, I learned of the Scythe Big Shuriken 2 (Rev B), which is what I ended up using for that machine. So, my Geminii M4 sat in a corner, unused, until now.
GeminII M4 CPU Air Cooler
GeminII M4 is a super low profile CPU cooler (59mm / 2.3in height) designed for a system with limited space, such as mini-ITX, HTPC, or any small desktop. With its 4 direct contact heat pipes and unique heat pipe layout, GeminII M4 not only keeps compact size but provides amazing cooling...
I wondered whether or not it had a compatible mounting system with my newer Cooler Master heatsink, and it turned out their bases are exactly the same! So, I began to wonder how it would perform, on CPUs higher-power than what it was originally designed for. This wasn't hard to guess, as you can find several comprehensive reviews of this cooler (see below). Still, I had a need, which the M4 could probably fill, and that was only amplified by my curiosity. So, here's what I learned.
Test Setup
Here are the key specs of the test setup:- Case: open bench
- Motherboard: ASRock Rack X570D4U-2L2T micro-ATX motherboard
- CPU: Ryzen 7 5800X
- Thermal compound: Arctic MX-6
- BIOS settings: mostly stock (no OC), but PPT set to 142 W.
- Fan curve: 100%, fixed speed.
- OS: Ubuntu Linux 24.04
- Ambient temperature: 25 C
- Monitoring:
turbostat --quiet --Summary --show=PkgWatt --interval=0.5
In addition to this, I used a custom python script to log the CCD and IOD temperatures.
Second, I had to use a lot of heatsink compound! I've never used so much on a heatsink, in my life! I know such an amount was necessary, because I had a few "oops" moments of the heatsink coming off the CPU, where I got to see how it had spread (and then cleaned it off and started over). It turns out that an "X" pattern didn't spread it well enough. only an "asterisk" pattern would cover the entire CPU. For the most part, this is due to the uneven base and gaps between the heat pipes. It also didn't help that the Cooler Master mounting system restricted my range of motion enough that I had to work the cooler back-and-forth for probably 5 minutes, before I consistently felt the metal-on-metal scraping that told me it had completely "landed".
Results
I found the CPU temperature plateaued rather quickly, thus 90 seconds was adequate for a test run. I tried a variety of workloads, increasing in their amounts of power consumption. What I discovered was that the CPU would throttle at 90 degrees. So, the way I decided to quantify the results, which I think should also be most applicable to others, is by looking at the peak amount of power output the cooler could dissipate, without throttling. That should make my findings applicable to different CPU models and workloads, as long as you can find out how much package power your combination can use. However, perhaps a dual-CCD CPU will manage a bit more power than what I observed.While the cooler could cope with brief spikes up to the 142 W package power limit, the limit of its sustained output on a strenuous lightly-threaded workload (FFT x5 threads) was about 105 W (CPU package power). That's conveniently equal to the stated TDP of the 5800X, but remember that's the point where it hits 90 degrees Celsius, which is where it throttled. So, I wouldn't recommend this specific cooler for anything above the models with 88 W PPT (which are the models advertised at 65 W TDP).
Note: This image replaces temperature data with clock speed. It was too cluttered to cram this all into a single plot.
With a lighter-weight, all-core workload, the cooler was able to sustain 119 W!
Note: As before, this plot replaces temperature data with clock speed.
As noted in the Test Setup section, the ambient temperature was about 25 degrees Celsius, during the above tests.
Alternate Fan
Since the cooler included only a 15 mm low-profile fan (120 mm length & width), I tried replacing it with a Noctua NF-A12x25 PWM. This is their current 120 mm flagship CPU fan, and not exactly cheap (25 mm thick). I tested this out of curiosity and because I already had the fan, rather than because it would make sense to buy such a low-end cooler and pair it with such a nice fan. In fact, while I could feel more air coming off it, the surprising result was no improvement!Seeking to investigate further, I discovered that I could actually touch all of the heat pipes, in a spot before they reached the fin array. One was noticeably warmer than the others, which was presumably the one hitting the CCD. Given this fact, it's not surprising that more airflow had no effect. The thermal bottleneck wasn't in the fin array. I found that a little incongruous with the fact that they'd gone to the trouble and expense of soldering the fins to the heat pipes.
Other Notes
When installing the heatsink, I tightened the fasteners all the way to the ends of the threaded portion. Since these bolts were specific to AM4, I figured they made the threads that long for a reason, and the instructions gave no guidance on how far to go.Subsequently, I tested reducing the mounting tension and found that I could reduce temperatures by about 1.2 degrees by backing off each of the nuts about 1.5 revolutions. This part is probably more generally interesting and relevant, so I plan to make a separate post about it. Therefore, I won't expound on it further, here.
Professional Reviews
In chronological order:- https://www.techradar.com/reviews/p...oling/cooler-master-geminii-m4-1041459/review
- https://www.madshrimps.be/2012/02/cooler-master-geminii-m4-cpu-cooler-review/
- https://silentpcreview.com/cooler-master-geminii-m4-low-profile-heatsink/
- https://www.goldfries.com/hardware-...ii-m4-low-profile-cpu-cooler-heatsink-review/
