[SOLVED] Using a U.2 Connector
Pyneappel
39
I have a mobo with a "double decker" U.2 connector. I guess this is also called SFF-8639? What is the easiest way to use this to connect an M.2 SSD or "normal" 2.5" SATA 3 SSD?
It looks like I have to buy either;
a) a cable that converts the double decker U.2 to a flatter connector and then a 2.5" case to put the M.2 stick in that has the flat U.2 connector on the outside
b) A cable or dongle that converts the double decker U.2 to a flat U.2 and then another cable or dongle that adapts the flat U.2 connector to the SATA 3 connection on the 2.5" SSD.
Neither of which seems very efficient or that it would work.
Is there nothing that allows me to more directly connect a common SATA 3 SSD or M.2 SSD NVMe stick to a U.2 "double decker" port? I see devices that go the other way; plugging a U.2 device into an M.2 port.
I suppose my bese option is just to use one of the mobo SATA 3 ports and ignore the U.2 port?
In practice U.2 is used only on 2.5" SSDs. Several enterprise SSD and server platform suppliers support the U.2 form factor.
Intel DC P3600 SSDPE2ME012T401 2.5" U.2 1.2TB
https://www.newegg.com/intel-dc-p3600-1-2tb/p/N82E16820167238
2.5-inch Form Factor
15mm Z-height
8639-compatible connector
Cable:
Funtin U.2 (SFF-8639) to HD Mini-SAS (SFF-8643) Cable Support All Vendor's 2.5'' NVMe SSD, Manufactured by Amphenol is available for about $30 on Amazon.
Here is a 400GB drive you can use with the above cable:
https://www.ebay.com/p/216503772?ii...d=2&itemid=223229526503&targetid=593772066413...
15mm Z-height
Cable:
https://www.mouser.com/datasheet/2/612/ssd-dc-p3500-series-product-spec-769401.pdf
Reactions: Pyneappel
