[SOLVED] Using an ipad to view a camera, deets inside
punkncat
Ambassador
We have a location that we would like to utilize an older ipad that will sit in an area with public access and view a Nest camera. It is a 6th gen A1954.
The desire is to have the people walking into a lobby (payment window area) to be aware of, and able to see themselves on the camera, knowing they are being recorded and curtail bad behavior.
That in itself isn't a difficult issue. I am aware how to set up the app and view. The challenge part is getting the ipad to show only the view of the one camera while being locked. I have tried to look for instruction on how to do so and apparently am not searching the right terms. I find that there is or was a "guided mode" that would allow you to set a particular app on screen, always on, and would require a password to change from said screen. That sounds about perfect, aside from the other comments where either it won't actually show a live feed Nest camera that way, or will constantly "auto" log out after about 20-30 mins.
Is it possible?
The PIN would be used to unlock. However sounds like you want it to stay on. Maybe the guided feature would help with that.
To stay on: Look under Settings>Display & Brightness>Auto-Lock. Choose never.
I don't have an iPad but the settings are similar to an iPhone.
That setting should keep the display on.
Reactions: punkncat
