Using an Old Case--What M/B?
Jambe
37
I recently uncovered an brand new, older case (Rosewill R115-P-BK RT).
Will any of the newer motherboards work in this case. It does have the 6 1/4"/16 cm rear panel which is what I am concerned about.
Motherboard recommendations for a low-end Intel build?
All cases should support micro ATX or full size ATX motherboards. The MSI B75MA-E33 is nice micro ATX board which should have everything you need. It has some USB 3.0 headers as well as a some on the back panel. It also has a HDMI output as well as VGA but down side is that it only has two slots for RAM. If your looking for something more higher end their's always the Z75 or 77. A budget would have been nice?
