Using auto voltages. Will i get better temps with manual voltages?
dazkyl
1,036
Right now my 4670k corei5 on asrock extreme6 z87 motherboard is idling at 35 degrees with a cm v6gt cpu cooler.
When playing bf4 on ultra settings , it was at 68degrees.
Speed is currently @4.4ghz and all voltages in bios are set to auto.Maybe thats why im not getting better temps , although theyre very decent the way they are now.
So my question is , will setting the voltages manually gives me better temps ?
I bought an ASRock extr6 z87 and im super happy with it ! handles overclocking like a boss
Yeah ASUS, ASRock and MSI motherboards are all fine, but when you get down to the details that really separates them, Gigabyte crushes them by using much higher quality components with better performance.
I myself first discovered this video last night. I was kinda shocked and glad that I bought a Gigabyte motherboard and not something else.
Which core should i reduce ? There are many cores and im getting confused.
Cheers ! I will have a look at it later on today , so i will tighten up my temps !
It's REALLY detailed so I'm sure it will help!
