Well here's a fix ... since CPU-Z --> Bench --> Stress CPU is only about 78% workload, just don't use it ... unless you're comfortable with the false sense of security that your Core temperatures in CPU-Z are really good.
Not all loads are created equal. Intel tests their processors at a
steady 100% TDP to validate Thermal Specifications.
Prime95 version 26.6 Small FFT's is ideal for CPU thermal testing, because it's a
steady 100% workload with
steady Core temperatures that typically runs processors within +/- a few % of TDP. No other utility so closely replicates Intel's test conditions. This is the utility Real Temp uses for testing Core temperature sensors.
Utilities that don't
overload or
underload your processor will give you a valid thermal baseline. Here’s a comparison of utilities grouped as
thermal and
stability tests according to approximate % of TDP, averaged across six processor Generations at stock settings:
Note where CPU-Z is on the lower end of the scale.
All tests will show 100% CPU
Utilization in Windows Task Manager, which seldom coincides with %TDP
workload. Higher TDP tests produce higher Core temperatures. Although actual Power dissipation (Watts) varies with Core Speed, Core voltage, cooling and workload, Prime95 v26.6 Small FFT’s always provides a steady 100% workload, whether you’re running stock or overlocked.
• Prime95 v26.6 -
http://www.mersenneforum.org/showthread.php?t=15504
Do
not use any versions later than 26.6.
Click on my signature and read our Guide.
CT
