Nayo :
USAFRet :
Nayo :
I have 2 hours tonight to clean up my PC and get going for tommorow. As i dont have grease and wanted to clean all the fans , how about using some coconut oil ? I mean it wont cause any problem right ?
You're asking 2 different things here, Lubrication and cleaning.
Which are you doing?
First cleaning and then lubricating . I was thinking of using coconut oil for a week . as i dont have grease . WIll it work or itll make a mess ?
Cleaning the fan should not require new lubrication. Unless you completely dunk it in soapy water.
Lube only if it is noisy.
