Hey y'all, I'm trying to build a system for gaming, rendering, game dev, and 3d modeling. My CPU is going to be either a 12900k or 12400kf (with a RTX 3090 Ti).
I've been looking into ram and though I would go for DDR4 and 2x16GB, with a speed of 3600 and CL14 memory (I chose the G.Skill TridentZ RGB 32 GB (2 x 16 GB) DDR4-3600 CL14 Memory).
But when I added the ram to my build (on PCPartPicker) I got a warning that the operating voltage of the memory (1.45 V) exceeded the recommended maximum of the Intel Alder Lake CPU (1.35 V):
So I thought, easy—I'll just find a different stick of memory with 1.35 V while still maintain a speed of 3600 and CL14 memory. Wrong! It seems like at the lower voltage I have to sacrifice either speed or CL memory.
For example, the best sticks that I could find the the G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory (keeps the speed but losses CL) and G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3200 CL14 Memory (maintains most of the CL but losses a lot of speed).
Is it better to shoot for speed vs CL memory? Or to buy the original stick (PCPartPicker said, "This memory module may run at a reduced clock rate to meet the 1350 mv voltage recommendation, or may require running at a voltage greater than the Intel recommended maximum.")? But would using ram with a higher voltage be worse than just taking the hit and buying cheaper ram?
Price isn't too much of an issue, and I wasn't really planning on overclocking at all.
I'm pretty new to memory and just don't want to bottleneck anything unnecessarily.
Thank you so much for your help!
