Hello everyone -
I am going overseas and bringing my work laptop which appears to have an eSatap (powered) port. I would like to be able to use my main boot SSD (Intel 160 GB) which I use in my home PC as a boot SSD for my work laptop.
At first I was looking at external enclosures, but am now wondering if it would be better to simply use a Sata to eSatap (or esata+usb) cable instead. Would the eSatap port provide enough voltage to power the SSD as a boot drive consistently, or would I be better off using an external enclosure with a power supply? It looks like eSatap ports typically provide about +5V while Sata ports can provide +12 V - will this be an issue?
If I must go the external enclosure route, I would like something that doesn't limit the eSata transfer rates AND is highly dependable/safe for my SSD. The Thermaltake BlacX external enclosure/dock (ST0005U) I've been looking at looks great EXCEPT that it limits the eSata speed by not bypassing the USB chip, which apparently severely limits speeds if you're using a SSD.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153071
Thanks to everyone in advance!
