Hi all,
I've been overclocking my Sapphire 6870 with AMD Overdrive (Catalyst 12.3) from 900 to 965, but was interested in going a little bit higher. Therefore, I'll need to switch to something that lets me alter the voltage.
I tried MSI afterburner, but it didn't let me control the voltage. I then tried Sapphire Trixx, and while it let me control the voltage, it forced the card to stay at high clocks/high voltage even when it wasn't under load. With AMD Overdrive my card will cycle down to 2d clock rates (300mhz@.95v) when its not under load. For some reason with Trixx it stayed at the 3d clock rates until I restarted my computer.
Is there someway I can increase the voltage without having the GPU remain at the higher clock speed even when not under load?
