[SOLVED] Using widescreen monitor as 2 monitors (Xiaomi Mi Curved)
algorian
Hello.
I've recently bought a Xiaomi Mi Curved.
It is really wide so I want to use it as two monitors with Picture by Picture (PBP) mode
The problem is when I switch to PBP mode, each side of the screen still uses the same resolution(3440x1440), but it gets squished horizontally to cover half of the screen(it covers the left side of the screen.
So I change the resolution to 1720x1440 to make it flat again.
Bu this time, it is still squished and covers only half of the left side, leaving half of the left side black.
Since this is a new product, there is no mention of this situation on the web.
This is the illustration of the situation.
As you can see, in the first row, the image is in its natural resolution.
But putting the monitor into PBP mode makes it squashed horizontally.
Changing the display card output to 1720x1440 puts black bars to the left and right of the image.
2x 1720x1440 is correct from windows/gpu display settings
see your monitor options if it supports pbp fullscreen, as far i can see its not enabled
