Question Verizon wifi router suddenly started giving intermittent connection
cgott42
32
I've had Verizon FIOS for roughly10-15 years. I have their 1gb router. It had been working great and then suddenly the wifi signal started to drop intermittently (and very often). The problem is even if you're right next to the router. The wired connections from the router work great, and if I connect (wire) a different wifi router to the Verizon router - that signal seems to work fine.
I had them send me a new router, which worked ok for a week, and now has the same problem.
The problem exists on the 2.4GHz, and 5GHz bands .
Further, I even put only 2 (core) devices on the 5GHz band, and still has a problem, in addition to the problem devices on the 2.4GHz band experience (even the IoT band)
I didn't make major changes (that I can recall)
I spoke to the Verizon tech, and they didn't have answers (though did send me a new router)
Any ideas?
It is very strange you have issues on both radio bands. These are different chips in the router. In addition replacing the router and having the same issue likely means it is not hardware in the router.
Pretty much all wifi problems are some kinda of interference from say your neighbors.
What is different between the router that you plug into the verizon router. Is it running and the same radio channels. Maybe try to force the verizon router to use the same channels as the router that works. Worst case there really is little disadvantage to running the second router for wifi. Be sure you run it in AP mode so you only have 1 network.
cgott42
32
thanks, what is "AP mode"?
Should be a setting in the router. What i basically does is change the wan port into a lan port and disables the dhcp function. You might have to change the lan ip if it doesn't do it by itself,
Almost all routers now have the feature, some call it bridge. If it does not there is a very old sticky on the top of this forum that tells how to use any router as a AP. Everything is still valid even if it is old but most routers support AP mode except say a dsl router.
