Question Very low 1% and 0.1% FPS and stuttering in various games on high end PC ?
5
So, I had a PC built in October 2024 and ever since I got it, I have been experiencing stutters with a lot of the games I play. I assumed it was some settings on my PC (BIOS, Windows, game) and tried fixing the stutters for over a month to no avail. Yes, I should have brought my PC back to the store where I had them build it, but unfortunately, there were some circumstances that prevented me from doing so. Since I wasn't under the store's warranty for any parts, I had to bring it in for a diagnostic at Geek Squad and the store I bought the parts from (and where I had it built).
Two of the games that perform the worst are Hogwarts Legacy and Red Dead Redemption 2, but other games experience some stuttering as well such as FFXV and Baldur's Gate 3, just not as bad. Geek Squad said they experienced stuttering on games and benchmarks they downloaded, so they reinstalled GPU drivers and chipset drivers, and said it fixed stuttering in the games and benchmarks they used except for Hogwarts, which still stuttered. They said they had no clue why Hogwarts stuttered and recommended I take the PC to the store I bought the parts at. So, I tested to see if the games I mentioned ran smoother now, but unfortunately, it was the same so I have no clue why they said they fixed it.
I then brought the PC to the store I bought the parts at. They ran various benchmarks (I forget the exact names of them, but they ran the benchmarks at 1440p high settings) and said they experienced stutters initially, but they reset all settings on my PC and reinstalled drivers, and it fixed stuttering on all games. They didn't know the exact setting that caused the stutters, but they just told me it runs completely fine. When I tested the games back at home after picking the PC up, the games still stuttered the same. I have tried just about everything I could before bringing the PC in for diagnostics and feel like I am out of options. I am considering taking it to a smaller business instead of a big computer store chain as a final attempt and figuring out the issue, but would like to see if I can ask you all for some help first.
I have tried multiple things to fix this issue. I cant remember exactly everything, but off the top of my head:
I turned on and off various settings in BIOS, Windows, and the games I played. I messed with the power plans and Nvidia Control Panel settings. I tried updating BIOS and reinstalling chipset drivers and GPU drivers. I reset Windows a total of 3 times. I ran Memtest to see if my RAM was faulty, but I passed. I downloaded different performance mods for the games I play to no avail. Tried using custom timings on YouTube for my specific CPU. I tried using different overclock profiles like EXPO 1 and 2, and none. I tried using the Studio Nvidia driver for me specific GPU instead of the Game Ready driver. Made sure I didn't have unnecessary apps in the background by closing them through Task Manager. I have also tried using FPS limits through both Nvidia Control Panel and Rivatuner. G Sync on and off. I have tested a ton of stuff I can't even remember. It got to the point where I had no more links on google that I DIDN'T visit before.
So, this leads me to my overall issue. I have determined the stuttering is due to very low 1% and 0.1% lows in games. The FPS will go from 110, down to 10-55 FPS at times, or lower in some cases. I experience these stutters the worst in RDR2 and Hogwart's Legacy. I experience these stutters others games as well such as Metro Exodus, Baldur's Gate, and FFXV, but not as much as RDR2 and Hogwart's. It is getting to the point where I am not even playing my PC unless I am playing multiplayer games and I am mainly playing my Switch because I can't deal with the stutters in every single player game I play. Some games run fine for the most part, with occasional stutters like Party Animals and Marvel Rivals, but the majority of games that require my GPU to work hard, there are stutters.
I would also like to mention that I get some of these stutters when my GPU isn't even at 100 percent. Same with my CPU. My GPU is usually around 70 - 90 percent utilized since I TRY to go for smooth frames. Usually, you would expect stutters to occur because the GPU is always hitting 100 percent utilization due to uncapped frames or too high graphics settings. Also, temps are not an issue. My PC is always cool for the most part.
I have taken 2 videos showing the stutters with an overlay displaying stuff like voltages, FPS values, utilization, etc..
These are the links:
View: https://www.youtube.com/watch?v=ZRtTtFxHlAc
(RDR2 Benchmark, capped 120 FPS)
View: https://www.youtube.com/watch?v=yIUEZGQF-7Q
(Hogwart's Legacy)
User Benchmark Results:
[UserBenchmarks: Game 334%, Desk 118%, Work 336%](https://www.userbenchmark.com/UserRun/69717862)
||Model|Bench
**CPU**|[AMD Ryzen 7 7800X3D](https://cpu.userbenchmark.com/SpeedTest/2081998/AMD-Ryzen-7-7800X3D-8-Core-Processor)|116.5%
**GPU**|[Nvidia RTX 4080-S (Super)](https://gpu.userbenchmark.com/Nvidia-RTX-4080-S-Super/Rating/4156)|298.1%
**SSD**|[WD Black SN850X M.2 2TB](https://ssd.userbenchmark.com/WD-Black-SN850X-M2-2TB/Rating/4158)|479.4%
**RAM**|[Unknown UD5-6000 2x16GB](https://ram.userbenchmark.com/SpeedTest/1942328/Unknown-UD5-6000-2x16GB)|188.7%
**MBD**|[Gigabyte GA-X670 GAMING X AX V2](https://www.userbenchmark.com/System/Gigabyte-GA-X670-GAMING-X-AX-V2/326815)|
My specs are:
RTX 4080 Super
R7 7800X3D
32 GB DDR5 RAM 6000 mHz CL 32
2 TB SN850X SSD
Gigabyte X670 Gaming AX X V2 MB
Windows 11
AW3423DWF Ultrawide Monitor
With the above videos, are you guys able to see anything abnormal? Any hardware that may be causing the stutters based on the videos? Thank you for any suggestions and support in advance. I have not had one smooth gaming experience since buying this PC and it sucks because of how much money I dropped on the parts and setup.
was windows installed with your current hardware?
update the nvidia driver to the latest version 572.16 and run userbenchmark again and post the link please
which graphics settings did you chose in the games?
take some screenshots of the settings, upload to imgur.com or similar and post the link
Windows was installed with my current hardware, yes.
UserBenchmarks: Game 342%, Desk 118%, Work 348%
CPU: AMD Ryzen 7 7800X3D - 119.1%
GPU: Nvidia RTX 4080-S (Super) - 299%
SSD: WD Black SN850X M.2 2TB - 502.3%
RAM: Unknown UD5-6000 2x16GB - 188%
MBD: Gigabyte GA-X670 GAMING X AX V2
This was done immediately after I installed new driver. In the videos, I show the settings I am pretty sure. I may have not for Hogwarts, but I did for RDR2. I also turned down shadow settings and texture quality settings and still got micro stutters.
