very low benchmarks in 3Dmark2003 and 2001SE
mvriend
I have run 3Dmark2003 and 3Dmark2001SE, the scores were very low. I have got a PIV1.8ghz, 768MB DDR PC2100 and a CLUB3D ATI RADEON 9800. Mainbord is an ASUS P4S533-E with a SIS645DX chipset. Mainbord supports up to 4x AGP.
I have no idea what should be so wrong
Newest IDE and AGP drivers are installed. I have tried ATI and OMEGA drivers. There is nearly no difference between them. Hopefully someone cna help me! Thanks in advance!
3DMark 2003 test results:
General Information
Operating System Microsoft Windows XP
DirectX Version 9.0b
Mobo Manufacturer
Mobo Model
AGP Rates (Current/Available) 4x / 1x, 2x, 4x
CPU Intel Pentium 4 1816 MHz
FSB 100 MHz
Memory 768 MB
Display Information
Graphics Chipset ATI RADEON 9800 PRO
Driver Name RADEON 9800 PRO (Omega 2.4.96b)
Driver Version 6.14.10.6396
Driver WHQL Certified No
Video Memory 128 MB
Core Clock 324 MHz
Memory Clock 290 MHz
Sound Information
Sound Adapter Driver Name Creative Sound Blaster PCI
Sound Adapter Driver Version 5.1.2535.0
Benchmark Settings
Program Version 3DMark03 Revision 2 Build 0
Resolution 1024x768@32 bit
Texture Filtering Optimal
Pixel Processing / Antialiasing None
Post Processing false
Vertex Shaders Optimal
Main Test Results
3DMark Score 1760 3DMarks
CPU Score 331.0 CPUMarks
Detailed Test Results
Game Tests
GT1 - Wings of Fury 70.1 fps
GT2 - Battle of Proxycon 7.7 fps
GT3 - Troll's Lair 7.5 fps
GT4 - Mother Nature 15.7 fps
CPU Tests
CPU Test 1 35.9 fps
CPU Test 2 6.1 fps
Feature Tests
Fill Rate (Single-Texturing) 1091.7 MTexels/s
Fill Rate (Multi-Texturing) 2264.5 MTexels/s
Vertex Shader 15.0 fps
Pixel Shader 2.0 26.6 fps
Ragtroll 4.2 fps
3DMark 2001SE test results:
System Configuration
DirectX Version 9.0
Mobo Manufacturer
Mobo Model
AGP Rates (Current/Available) 4x / 1x 2x 4x
FSB 100 MHz
Memory 768 MB
Video Memory 128 MB
Program Version 3DMark2001 SE
Resolution 1024x768 32bit
Texture Format Compressed
FSAA Disabled
Z-Buffer Depth 24bit
Frame Buffer Double
Rendering Pipeline D3D Pure Hardware T&L
3DMark Score 7282 3D marks
Game 1 Car Chase - Low Detail 102.0 FPS
Game 1 Car Chase - High Detail 37.3 FPS
Game 2 Dragothic - Low Detail 132.7 FPS
Game 2 Dragothic - High Detail 75.2 FPS
Game 3 Lobby - Low Detail 101.5 FPS
Game 3 Lobby - High Detail 49.7 FPS
Game 4 Nature 33.9 FPS
Fill Rate (Single-Texturing) 1243.2 MTexels/s
Fill Rate (Multi-Texturing) 2491.4 MTexels/s
High Polygon Count (1 light) 45.6 MTriangels/s
High Polygon Count (8 lights) 14.9 MTriangels/s
Environment Bump Mapping 150.4 FPS
DOT3 Bump Mapping 64.1 FPS
Vertex Shader 50.5 FPS
Pixel Shader 90.8 FPS
Advanced Pixel Shader 71.8 FPS
Point Sprite 5.8 MSprites/s
Thanks,
Marcel
In the ATI control panel under D3D, turn off vsync, and turn anti-aliasing and anisotropic filtering to "application preference". 03 you should get 5000ish, 01 you should get at least 14000ish. Close any resource hogs running in the background. Oh, and overclock everything!
If this dosn't get you at least close to the scores I've mentioned, well then, I'd shove a stick of dynomite up my ass and kill myself.
SIGNATURE: Stop asking people "whats up" or "hows it goin", you know you don't give a sh*t. And noone cares how you're doing either.
"We are far less than we knew." - Bright Eyes
NV Fanboy-
No Will you missed the obvious! He has an ATI card! OMG!!! WTF is he thinking???!!?!11?? BURN the card of D00M now or it will BLOW UP your MONITOR!!11!!!
My system spec: Fast PC<A HREF="http://service.futuremark.com/compare?2k1=7000747" target="_new"> 3D-2001 </A>
"It's not the spoon that bends, it's only yourself."
Did you swap out the motherboard without re-installing windows at any point?
HDD got DMA turned on?
HDD sharing a cable with a CDROM?
Has this just started happening, or always been like this?
Have you just replaced the graphics card without un-installing the old drivers?
If not, have you done anything else, hardware-wise or software-wise recently?
[Adding to Speeduk..]
And they cheat!!! Their performance isn't real!!!! THEY JUST LIE IN THE BENCHMARKS!!!!!!!!!!!!!
[/Adding to Speeduk..]
<font color=red>The preceding text is assembled from information stored in an unreliable organic storage medium. As such it may be innacurate, incomplete, or completely wrong</font color=red> :wink: <P ID="edit"><FONT SIZE=-1><EM>Edited by ChipDeath on 10/29/03 04:54 PM.</EM></FONT></P>
When I disable AA and AF on the control panel i get a score of 4587 in 3Dmark 2003. When I enable 4X AA and disable AF i get a score of 2768.
Is this normal or seems to be something totally wrong? DMA is on, cd is not on same cable as harddisk. Before this ATI RADEON9800 I had a GF4 MX440. I have totaly removed XP so all nvidia drivers were removed.
~4500 3DMarks sounds fine. AA and AF both have a pretty large impact on performance.
Don't tell me you think these guys getting 25000 3Dmark2001 scores are running with AA & AF?
What are your 2001SE scores with them both off?
Er... um... well, antialiassing and anistropic filtering aren't free, see?
The cost is a huge performance hit.
Otherwise, there wouldn't be an option to turn them on or off, they'd just be on all the time, you know?
Radeon 9500 (hardmodded to PRO, o/c to 322/322)
AMD AthlonXP 2400+ (o/c to 2600+ with 143 fsb)
3dMark03: 4055
I woundn't think so, I get a bit over 11,000 with my rig below and its stock.
btw, I used same resolution too.
It seems to me that there's an option on main screen to select high/low detail. I used low. I can't see on your test results what you used? I believe I ran it both ways and had a pretty good hit on my score when running w/high selected.
Sorry I can't be more specific, but I'm at the office and my rig is at home.
XP 2000+
MSI KT3 ULTRA-2 KT333
Maxtor 60GB ATA 133 7200RPM
512MB PC2700
ABIT G4 Ti4200 OTES 64MB
Win98SE<P ID="edit"><FONT SIZE=-1><EM>Edited by Coyote on 10/29/03 05:38 PM.</EM></FONT></P>
hey man your not the only one i've been getting bad scores as well *cries*
and guys if u want to be fanboyistic, do it right
OFCOURSE U GET LOW SCORES! you got a 9800pro here running 3Dmarks 2001 and 2003 we all know 3Dmarks run best on nVidia hardware, you know what? everything run best on nVidia hardware, for HL2 they put in a block in the programming so ONLY nVidia cards can't produce shaders correctly, damn Valve, they got bribe by ATi because ATi's got no other companies supporting them. FX5950Ultra owns 9800XT desprite what you see, all the hardware sites are bribed by ATi, and ATi is run by MOJO, there's no way they could beat nVidia i mean Forceware OWNS Catalyst, i mean who needs to update drivers monthly when u can do it YEARLY, i mean that's just so pro how nVidia's doing it~~
sigh~~ nVidia rules all and ATi sux
RIP Block Heater....HELLO P4~~~~~
120% nVidia Fanboy
bring it fanATics~~ nVidia PWNS all!
SCREW aBOX! LONG LIVE nBOX!!
Are you drunken lately? Otherwise all i see in your post lately has been brutal ATi bashing without representing fact.
XP2000, R9700 & 512mb RAM gets me 11000-12000 so I would say yeah... if your P4 is a S423 core...
Trust me I know what I'm doing... ooops, grab the cat...
Those scores are right inline for your rig, you should never Benchmark with AA or AF on and expect good scores, always run the default settings and make sure AA and AF as well as VSYNC are disabled in the ATI control panel.
"I'd rather laugh with the sinners than cry with the saints."
Also, if your so taken with your benchmark scores you need to OC that 9800np you got.
That's a fairly reasonable score, but the rest of your system is definitely holding your Gfx card back quite a bit. You should find any modern game runs fine though.
Don't worry too much about 3dMarks, they're only a rough estimate compared to 'the real world'. Just play whatever games you like, and if they run ok, then be happy! :smile:
oh my god dude, did u see? i said it's a example of nVidia fanboyism -_-
120% nVidia Fanboy
funny how u didn't catch my sarcasm in there 😛
WHO NEEDS QUANTITY WHEN WE HAVE QUALITY!
120% nVidia Fanboy
Squirtles knows how to use sarcasm as a literary tool? Holy Crap!@#$
<b>Got any of that beer that has candy floating in it? You know, Skittlebrau? </b> <i>Homer Simpson</i>
TKS
