VERY low FPS in Skyrim
Crimson Cross
4
Hello, I know a lot of people have had issues with Skyrim and I'm no exception. I'm not sure if it's my video card or not but while playing I have FRAPS going (I'm trying to do a "Lets Play" of the game) and my FPS while moving about is 5, when I look at the ground it's a 10, and when I'm at a menu it's a 60. This is with the resolution at 960x600 and everything turned all the way down. I'm also on a fresh install so I can find the cause of the problem easier.
My specs
CPU speed 3.21 GHz
system memory 3.75 GB
video card memory 1.72 GB
HD space 465.66 GB
The reason your FPS is low, is mainly due to the fact that your bottlenecking your whole system through the intergrated graphics chipset.
I'd suggest that purchase a dedicated graphics card, minimum would be a HD 6670 or GTX 550 if you want to get any sort of reasonable performance out of skyrim.
Ran dxdiag and this is the info....
System Information
Time of this report: 4/25/2012, 19:27:47
Machine name: DAVID-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120305-1505)
Language: English (Regional Setting: English)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: Default System BIOS
Processor: Pentium(R) Dual-Core CPU E5800 @ 3.20GHz (2 CPUs), ~3.2GHz
Memory: 4096MB RAM
Available OS Memory: 3838MB RAM
Page File: 4037MB used, 5552MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) G41 Express Chipset
Manufacturer: Intel Corporation
Chip type: Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2E32&SUBSYS_2E321849&REV_03
Display Memory: 1759 MB
Dedicated Memory: 128 MB
Shared Memory: 1631 MB
Current Mode: 1680 x 1050 (32 bit) (59Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: L19W898
Monitor Id: EPIE190
Native Mode: 1680 x 1050(p) (59.954Hz)
Output Type: HD15
Driver Name: igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
Driver File Version: 8.15.0010.2413 (English)
Driver Version: 8.15.10.2413
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 6/3/2011 13:34:10, 6549504 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6D72-11CF-9472-380EA3C2C535}
Vendor ID: 0x8086
Device ID: 0x2E32
SubSys ID: 0x2E321849
Revision ID: 0x0003
Driver Strong Name: oem5.inf:Intel.Mfg.NTamd64:iEGL0:8.15.10.2413😛ci\ven_8086&dev_2e32
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0662&SUBSYS_18493662&REV_1001
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.01.7601.17514 (English)
WHQL Logo'd: Yes
Date and Size: 11/20/2010 22:23:47, 350208 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Headphones (High Definition Audio Device)
Default Sound Playback: No
Default Voice Playback: Yes
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (High Definition Audio Device)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Microphone (2- USB2.0 MIC)
Default Sound Capture: No
Default Voice Capture: No
Driver Name: USBAUDIO.sys
Date and Size: 11/20/2010 22:23:47, 109696 bytes
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x27CB
| Matching Device ID: usb\root_hub
| Service: usbhub
Gameport Devices
PS/2 Devices
+ Standard PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ HID-compliant mouse
| Vendor/Product ID: 0x0461, 0x4D22
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 102.5 GB
Total Space: 476.8 GB
File System: NTFS
Model: WDC WD5000AAKX-001CA0 ATA Device
Drive: Q:
Model: n/a
Drive: D:
Model: HL-DT-ST DVDRAM GH24NS70 ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes
Drive: E:
Model: DTSOFT Virtual CdRom Device
System Devices
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_27D8&SUBSYS_36621849&REV_01\3&11583659&0&D8
Driver: n/a
Name: Intel(R) 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller - 27C0
Device ID: PCI\VEN_8086&DEV_27C0&SUBSYS_27C01849&REV_01\3&11583659&0&FA
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D2
Device ID: PCI\VEN_8086&DEV_27D2&SUBSYS_27D21849&REV_01\3&11583659&0&E1
Driver: n/a
Name: Intel(R) 82801GB/GR (ICH7 Family) LPC Interface Controller - 27B8
Device ID: PCI\VEN_8086&DEV_27B8&SUBSYS_27B81849&REV_01\3&11583659&0&F8
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D0
Device ID: PCI\VEN_8086&DEV_27D0&SUBSYS_27D01849&REV_01\3&11583659&0&E0
Driver: n/a
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_244E1849&REV_E1\3&11583659&0&F0
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
Device ID: PCI\VEN_8086&DEV_27CC&SUBSYS_27CC1849&REV_01\3&11583659&0&EF
Driver: n/a
Name: Realtek RTL8102E/RTL8103E Family PCI-E Fast Ethernet NIC (NDIS 6.20)
Device ID: PCI\VEN_10EC&DEV_8136&SUBSYS_81361849&REV_02\4&1BA3C945&0&00E1
Driver: n/a
Name: Intel(R) G41 Express Chipset
Device ID: PCI\VEN_8086&DEV_2E32&SUBSYS_2E321849&REV_03\3&11583659&0&10
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
Device ID: PCI\VEN_8086&DEV_27CB&SUBSYS_27CB1849&REV_01\3&11583659&0&EB
Driver: n/a
Name: Intel(R) 4 Series Chipset Processor to I/O Controller - 2E30
Device ID: PCI\VEN_8086&DEV_2E30&SUBSYS_2E301849&REV_03\3&11583659&0&00
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
Device ID: PCI\VEN_8086&DEV_27CA&SUBSYS_27CA1849&REV_01\3&11583659&0&EA
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
Device ID: PCI\VEN_8086&DEV_27DF&SUBSYS_27DF1849&REV_01\3&11583659&0&F9
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
Device ID: PCI\VEN_8086&DEV_27C9&SUBSYS_27C91849&REV_01\3&11583659&0&E9
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) SMBus Controller - 27DA
Device ID: PCI\VEN_8086&DEV_27DA&SUBSYS_27DA1849&REV_01\3&11583659&0&FB
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
Device ID: PCI\VEN_8086&DEV_27C8&SUBSYS_27C81849&REV_01\3&11583659&0&E8
Driver: n/a
DirectShow Filters
DirectShow Filters:
QuickTime Audio Decoder Filter,0x00600800,1,1,gzHF330.ddc,1.01.0000.0017
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
QuickTime Video Decoder Filter,0x00600800,1,1,mtw178.ddc,1.01.0000.0017
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
WMT MuxDeMux Filter,0x00200000,0,0,WMM2FILT.dll,2.06.4037.0000
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3538.0513
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
RealPlayer Video Filter,0x00200000,1,1,rdsf3260.dll,15.00.0000.0198
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
WMT AudioAnalyzer,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DivX AAC Decoder,0x00800000,1,1,daac.ax,8.08.0000.41966
WMT Format Conversion,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
WMT Black Frame Generator,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
Van Overlay Filter,0x00200000,1,1,,
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
WMT Screen Capture filter,0x00200000,0,1,WMM2FILT.dll,2.06.4037.0000
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
WMT Import Filter,0x00200000,0,1,WMM2FILT.dll,2.06.4037.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Bitmap Generate,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
WMT VIH2 Fix,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
Record Queue,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
WMT Audio Mixer,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
Xvid MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
Frame Eater,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17713
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
DivX H.264 Decoder,0x00800000,1,1,DivXDecH264.ax,9.00.0001.0021
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
DivX Demux Filter,0x00800002,0,1,DirectShowDemuxFilter.dll,1.00.0003.0111
File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
DivX Decoder Filter,0x00800000,1,1,DivXDec.ax,7.03.0000.0048
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
DivX Demux Filter (Unrestricted Edition),0x00600000,0,1,DirectShowDemuxFilter.dll,1.00.0003.0111
WMT Sample Information Filter,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
Sony Wave Hammer Surround,0x00200000,1,1,mchammer.dll,1.01.0000.2267
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
WMT Log Filter,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
WMT Virtual Renderer,0x00200000,1,0,WMM2FILT.dll,2.06.4037.0000
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17713
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
WMT DirectX Transform Wrapper,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
RealPlayer Transcode Filter,0x00600000,0,0,rdsf3260.dll,15.00.0000.0198
Viscomsoft Screen capture filter,0x00200000,0,1,,
9x8Resize,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
Allocator Fix,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
WMT Virtual Source,0x00200000,0,1,WMM2FILT.dll,2.06.4037.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
WMT Interlacer,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
Van Reversal Filter,0x00200000,1,1,,
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17713
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,15.00.0000.0198
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
WMT DV Extract,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
WMT Switch Filter,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
WMT Volume,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
Stretch Video,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
Sony ExpressFX Chorus,0x00200000,1,1,sfxpfx2.dll,1.01.0000.2267
Sony ExpressFX Delay,0x00200000,1,1,sfxpfx2.dll,1.01.0000.2267
Sony ExpressFX Distortion,0x00200000,1,1,sfxpfx1.dll,1.01.0000.2267
Sony ExpressFX Equalization,0x00200000,1,1,sfxpfx2.dll,1.01.0000.2267
Sony ExpressFX Flange/Wah-Wah,0x00200000,1,1,sfxpfx1.dll,1.01.0000.2267
Sony ExpressFX Amplitude Modulation,0x00200000,1,1,sfxpfx2.dll,1.01.0000.2267
Sony ExpressFX Reverb,0x00200000,1,1,sfxpfx1.dll,1.01.0000.2267
Sony ExpressFX Stutter,0x00200000,1,1,sfxpfx1.dll,1.01.0000.2267
Sony ExpressFX Dynamics,0x00200000,1,1,sfxpfx3.dll,1.01.0000.2267
Sony ExpressFX Graphic EQ,0x00200000,1,1,sfxpfx3.dll,1.01.0000.2267
Sony ExpressFX Noise Gate,0x00200000,1,1,sfxpfx3.dll,1.01.0000.2267
Sony ExpressFX Time Stretch,0x00200000,1,1,sfxpfx3.dll,1.01.0000.2267
Sony ExpressFX Audio Restoration,0x00200000,1,1,xpvinyl.dll,1.01.0000.2267
Sony Multi-Band Dynamics,0x00200000,1,1,sfppack2.dll,1.01.0000.2267
Sony Track Compressor,0x00200000,1,1,sftrkfx1.dll,1.01.0000.2267
Sony Dither,0x00200000,1,1,sftrkfx1.dll,1.01.0000.2267
Sony Chorus,0x00200000,1,1,sfppack1.dll,1.01.0000.2267
Sony Distortion,0x00200000,1,1,sfppack3.dll,1.01.0000.2267
Sony Gapper/Snipper,0x00200000,1,1,sfppack3.dll,1.01.0000.2267
Sony Simple Delay,0x00200000,1,1,sfppack1.dll,1.01.0000.2267
Sony Reverb,0x00200000,1,1,sfppack1.dll,1.01.0000.2267
Sony Multi-Tap Delay,0x00200000,1,1,sfppack1.dll,1.01.0000.2267
Sony Track Noise Gate,0x00200000,1,1,sftrkfx1.dll,1.01.0000.2267
Sony Graphic EQ,0x00200000,1,1,sfppack2.dll,1.01.0000.2267
Sony Track EQ,0x00200000,1,1,sftrkfx1.dll,1.01.0000.2267
Sony Smooth/Enhance,0x00200000,1,1,sfppack3.dll,1.01.0000.2267
Sony Resonant Filter,0x00200000,1,1,sfresfilter.dll,1.01.0000.2267
Sony Parametric EQ,0x00200000,1,1,sfppack2.dll,1.01.0000.2267
Sony Time Stretch,0x00200000,1,1,sfppack1.dll,1.01.0000.2267
Sony Noise Gate,0x00200000,1,1,sfppack2.dll,1.01.0000.2267
Sony Paragraphic EQ,0x00200000,1,1,sfppack2.dll,1.01.0000.2267
Sony Vibrato,0x00200000,1,1,sfppack3.dll,1.01.0000.2267
Sony Pan,0x00200000,1,1,sffrgpnv.dll,1.01.0000.2267
Sony Pitch Shift,0x00200000,1,1,sfppack1.dll,1.01.0000.2267
Sony Volume,0x00200000,1,1,sffrgpnv.dll,1.01.0000.2267
Sony Flange/Wah-wah,0x00200000,1,1,sfppack3.dll,1.01.0000.2267
Sony Graphic Dynamics,0x00200000,1,1,sfppack2.dll,1.01.0000.2267
Sony Amplitude Modulation,0x00200000,1,1,sfppack3.dll,1.01.0000.2267
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
DivX 6.9.2 Codec (2 Logical CPUs),0x00200000,1,1,qcap.dll,6.06.7601.17514
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft MPEG-4 Video Codec V2,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft MPEG-4 Video Codec V1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Xvid MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
DivX 6.9.2 YV12 Decoder,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
Audio Capture Sources:
Microphone (High Definition Aud,0x00200000,0,0,qcap.dll,6.06.7601.17514
Microphone (2- USB2.0 MIC),0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
WDM Streaming Capture Devices:
HD Audio Microphone,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
USB2.0 PC CAMERA,0x00200000,1,2,ksproxy.ax,6.01.7601.17514
USB2.0 MIC,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
HD Audio Headphone,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
HD Audio Speaker,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (High Definition Audio,0x00200000,1,0,quartz.dll,6.06.7601.17713
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Headphones (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7601.17713
Headphones (High Definition Aud,0x00200000,1,0,quartz.dll,6.06.7601.17713
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
well your using a intel chipset (it will never compare to amd or nvidia gpu)
even if it says 100000000gb vram, it will never be enough.
edit: btw also your cpu is not fast >.<
edit2: oh and fraps cuts off your FPS by a big margin
