Very low FPS when starting games despite upgrading graphic card
sooahgracie
5
Hi everyone,
I recently changed my graphics card to NVIDIA GeForce GTX 1050, but I'm having major FPS issues when gaming.
The problem mostly occurs when playing Overwatch, where I have 10 -15 FPS in the start. It eventually gets better after 30 minute of so, but I still get random frame drops...
Here are my specs:
ASUSTek Computer INC. P8H67-M LX
Intel Core i5-2500 CPU @ 3.30GHz
4GB Ram
I've already tried uninstalling the graphics card driver and installing the updated version, and the temperature always stay around 35-40C.
I'm pretty new to all this computer stuff, so please give easy to understand advice. Thank you all so much!
4gb is very low
also since your computer is quite old
I bet you still using an old HDD which doesn't help a lot, especially because it is probably cache swapping all the time.
either upgrade ram
get an ssd
or best of both worlds = get both!
What was your previous card? You may need to remove the previous drivers via Control Panel and do a clean install of the Nvidia drivers. During installation there's a option during installation to perform a clean installation (check box), doing this will remove old Nvidia drivers that may be conflicting and only install the newer ones.
And yes, 4gb is low for a gaming system however if your not running multiple apps in the background it shouldn't be affecting your gaming that much.
Temps for both CPU & GPU should be under 80C while gaming.
