Hi guys ,
I am facing a really annoying problem with my vga. I own a HD 6850 Windforce edition graphics card.It has two fans on the cooler. One of the fans though makes a noise. It sounds like something got stuck inside of the fan and it spins all over it . But actually there is nothing. I didn't see something bothering the fan spin. So I downloaded msi afterburner just to decrease the fan speed and nothing happened. Finally I found a "trick" if u can call it so : When the pc starts the fan is noisy , then I open up msi afterburner and I increase the speed of the fans to 75-80% for about 5 minutes. After 5 minutes I set it back to default and u cant hear the noise anymore. Does anyone know what is wrong with that fan ? Should I replace it ? If so what fan should I buy. Should I repair it ?
Thank you guys in advance !!
