VGA no signal
ShadowEA
32
Hello, I have Asus vw221D monitor and now i bought the radeon r9 270x but when I plug in the VGA to DVI converter on cable and run PC I get a message VGA no signal. Have 3 different vga to DVI adapters and none seems to work also my monitor have only vga input on it but it's LCD 21.5" and most people told me that I only need the adapter to make it work.
Just to note on old graphic card, vga input works, dvi input with adapter is not working same as on new graphic card but the new one has no vga input.
So I need some advice since I'm so desperate atm.
The issue must be the video card then. Do you have the PCIe external power connected to the video card from the power supply? Also, what make/model of power supply are you using?
Minimum System Power requirement (W): 500W
External Power Connector: Two 6-Pin PCI Express Power Connectors
At store they told me that my monitor doesn't support dvi input and that i need to reinstall the amd drivers on another monitor which support dvi and after that i can use dvi.
Latest posts
