VGA Port Problem
Enerpi_0016
39
Good day everyone! I'm planning to change my GPU. I will buy the Gigabyte Geforce GTX 1060 Windforce OC 6GB. I noticed that the GPU doesn't have a VGA. My monitor (Samsung SyncMaster B1930) only have VGA. So what am I going to do? Is there a connector that have a VGA and HDMI? If so, please give some pictures/link of this connector.
PS: I don't have a plan to buy a new monitor so please give me some good options :)
THAT'S ALL, THANK YOU
offroadguy56
450
If you have a DVI-I port you can easily convert from DVI to VGA. See image http://s.hswstatic.com/gif/dual-dvi.jpg
The above picture is a DVI-I, if your card has the top port go to your local computer shop and pick up a DVI to VGA adaptor for $5.
If you have the below port you will need an active adapter from whatever port you choose on your card to VGA.
Enerpi_0016
39
[quotemsg=19551294,0,1294572]If you have a DVI-I port you can easily convert from DVI to VGA. See image http://s.hswstatic.com/gif/dual-dvi.jpg
If you have the below port you will need an active adapter from whatever port you choose on your card to VGA. [/quotemsg]
I'm afraid that the Gigabyte 1060 has only DVI-D... so im going for the HDMI.. Thank you for your answers
