VGA Power won't go in the whole way
On the eight pin 12v Pci-e power block from the Psu to the connector on your GTX 1070 card.
The 12v Pci-e power connector from the Psu will have a claw hook latch Paradox.
As in this picture of the eight pin 12v Pci-e power from the Psu.
While inserting the eight pin power block to the card
https://www.google.co.uk/search?q=12v+eight+pin+pci-e+power+connector&espv=2&biw=2048&bih=1062&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiutOjj95zQAhUMDsAKHVdcDoUQ_AUIBigB#imgrc=Y90km_7WR6v_OM%3A
Push the tab in over at the top while inserting the power block to the GTX 1070 card you have.
It should then fit and line up without a gap between the female connector on the card and the male connector from the Psu ok.
