Question VGA white light
May 8, 2021
After i switch on my pc it shows DELL logo then the screen is greyed out and Motherboard shows VGA white light, but i wait for 3 minutes bios loading and the VGA lights are off. Whats the solution for this?
My spec--
PROCESSOR - i5 9400f
GPU- nvidia geforce GTX 1050 TI 4GB DDR5
RAM-16GB
POWER SUPPLY - 650W
Ralston18
New build or a build that has been working for awhile? Any known hardware or software changes?
Make and model motherboard?
PSU: make, model, wattage, age, condition.
Are you able to try another known working video cable between GPU and monitor. Or try connecting the GPU to other monitors via other GPU ports and known working cables and monitor.
Will the system boot if you remove the GPU and use integrated graphics (if supported)?
Go to the motherboard's manufacturer's website and find the applicable motherboard User Guide/Manual.
The manual should explain the meaning of the VGA light being on or off.
