I have the Powertech CAB-H164 external video capture device which is an inexpensive device but seems to work fine. The only problem I have is that recording sound seems to produce a background static noise. The way this thing works is you connect the hdmi from the source (Android TV box in my case) and then you connect the usb 3.0 to your pc.
The ways that you can record sound are two (the two I know at least):
- From the usb 3.0 of the device to the pc usb (with a male to male usb a cable): Windows will detect the device as a usb microphone
- From the 3.5 "audio out" jack to the pc's "mic in" jack (with a 3.5m male to mal cable): Windows will detect the device as a microphone
*Software used: OBS (I also tried Audition to make sure)
I've tried both ways and the static sound is there on both. The only difference is that via the usb the sound is more of a "hiss" while with the 3.5mm jack it's more of a crackling sound.
Now, as far as troubleshooting goes:
- If I connect a pair of earphones on the 3.5 sound out jack of the device the sound I hear is perfectly clear. So that leaves out a faulty video capture device or hdmi cable,
- I tried other sources other than my TV box and the results are the same. So that leaves out a problematic source device
- For connecting the 3.5mm to the PC: I tried both the front panel mic-in hole and the hole in the back of the tower
So I don't get how I can hear sound fine (from the "sound out" jack of the device) but transmitting it to the "mic in" jack of the pc it creates this static.
EDIT: Added a schematic of the two configurations
