My setup:
CPU: I5 4690k
Mothterboard: Gigabyte GA-Z97X Gaming 3
RAM: G.Skills Trident X 16gb (2x8) 2133mhz
Storage: Samsumg 850 evo 120mb SSD & WD 1tb HDD
Video Card: EVGA Geforce GTX 960 SuperSC ACX 2.0+
Cooler: EVO 212
PSU; Corsair RM850
Case: Zalman Z11 NEO
When I connect the video card to the monitor, I get no signal. When I connect the motherboard to the monitor, I get a signal with no problem.
The video card has 1 8pin plug on it. The PCI-e chords that came with the PSU are 8pin from the PSU splitting to 2 6+2pins. At first, I connected I 6+2pin(leaving the other 6+2pin free) to the 8pin on the video card. The 2 fans on the card would sputter. 1 fan would sputter 3 times, then the other fan would sputter 3 times, repeating in that sequence.
The video card also came with it's own splitter, an 8pin from the card to 2 6pins connectors. So then I connected the card's splitter and connected the 2 6pins on the PSU's chord, leaving both +2 parts of the 6+2 free. With this connection, both fans spin together for 15 seconds, and then stop, and remain stopped. This combo still netted no signal.
I then connected 2 seperate PCI-e chords to the PSU, then took 1 6pin from each PCI-e chord to each of the 6pin connectors on the card's splitter. This also resulted in both fans spinning for 15 seconds, then stopping and remaining stopped, also netting no signal.
Please help! This a gaming PC build that was suppose to be ready for my son for Christmas. Thank you everyone!
CPU: I5 4690k
Cooler: EVO 212
PSU; Corsair RM850
