dotaloc
[citation][nom]Cons29[/nom]i know higher than 1080 is better, but personally im not looking for that yet since i play games a lot. With higher than 1080 my current setup will choke. Maybe when im able to buy high end video cards that can handle those. right now, mid range is all i can afford.and maybe when movies go beyong full hd[/citation]
I know what you mean...but if prices were similar, you could get a 16:10 then disable 'expand to fullscreen' in the monitor (i've always seen that option in LCDs and it is usually on) settings and play t he game at whatever resolution you wanted. You aren't pushing any more pixels and your picture/AR doesn't get stretched/skewed.
Worse case, you get a non stretched (smaller) picture with a higher pixel density -- if you are sitting in front of the monitor, it will probably improve perceived image quality at my assumed distance -- from couch may be a different story.
...finding a 16:10 at the same price as a 16:9 one, though, may prove tricky...
